5 Replies Latest reply on Jun 17, 2009 9:55 AM by Hydrowizard
    Not scrolling all the way down
    Hydrowizard Level 1
      I am trying to change this but it isn't working-what is the code I need to change. Thank you.  www.copywritecolombia.com/flashsidemainold.fla  (CS3)
        • 1. Re: Not scrolling all the way down
          it's less likely you'll get help if downloading a file is required vs. answering a question when you supply the needed information.  in your situation, the probable needed information would be that used to assign text to your textfield and the scrolling code.
          • 2. Re: Not scrolling all the way down
            Hydrowizard Level 1
            Ok thanks for that question- it really needs to be downloaded thogh to see what I mean. It's only 170k I think. Cheers
            • 3. Re: Not scrolling all the way down
              Hydrowizard Level 1
              This code may help? Thanks
              onClipEvent (load) {
                  movespeed = 5;
              onClipEvent (enterFrame) {
                  if (Key.isDown(Key.RIGHT)) {
                      this._y -= movespeed;
                      if (this._y<=-421.4) {
                          setProperty("_root.scroll", _y, -621.4);
                  } else if (Key.isDown(Key.LEFT)) {
                      this._y += movespeed;
                      if (this._y>=57) {
                          setProperty("_root.scroll", _y, 57);
              • 4. Re: Not scrolling all the way down
                try:
                    movespeed = 5;
                           setProperty("_root.scroll", _y, -421.4);
                        if (this._y>=57) {
                • 5. Re: Not scrolling all the way down
                  Hydrowizard Level 1
                  Thanks for the answer but it doesn't make any difference unfortunately,
