8 Replies Latest reply on Jun 16, 2009 5:26 PM by kglad
    Stopdrag() help!
    javageek1212
      Ok I have a object in an ISOmetric room I made and I made bounds that are as tall as the char so that he could not go up the wall...
      I'm wanting do do the same thing with a dynamically loaded SWF that contains and object that can be moved around and stuff,
      well I have tried to make it so that when it collides with the bounds I made for the man it would stopdrag() but it won't!
      Is there another way I could do this or a way to impove the current way???
      -javageek
        • 1. Re: Stopdrag() help!
          why is your stopDrag() not working?
          • 2. Re: Stopdrag() help!
            javageek1212 Level 1
            Well im trying to stop the drag from another movieclip once it hittest the bounds on the _root
            • 3. Re: Stopdrag() help!
              christoon_ca Level 1
              could you post your script so we have a clearer understanding?
              • 4. Re: Stopdrag() help!
                Well I can't really post the script cause it's broken up but I will give you an example:
                I have a movieclip on the _root called wall and then I have a clip called box.
                I want the box to startdrag() when I press it but I already know how to startdrag()!
                The wall when it detects collision with the box I want it to stopdrag() the code for startdrag() is on the box clip
                and the hittest is going to be on the wall clip.
                How do I make it stopdrag from the wall clip?
                -javageek
                • 5. Re: Stopdrag() help!
                  from what I gather you need something like this:
                  box.onPress = function(){
                  startDrag(this,true
                  box.onReleaseOutside = function(){
                  this.stopDrag();
                  or this:
                  function checkTarget(drag) {
                        if (drag.hitTest(wall) {
                             stopDrag()
                  I learned some good basic drag stuff from this tutorial
                  • 6. Re: Stopdrag() help!
                    How do I implement and use those?
                    -javageek
                    • 7. Re: Stopdrag() help!
                      I would highly recommend checking out that tut link in my last post.
                      so this would be sitting on frame 1 of main timeline. "box" refers to your drag object.
                      //after startDrag is your target (your box, or "this" can be used), then whether the target drags from click point or center (true/false) lastly: the constraining coordinates which read "left, top, right, bottom" (in pixels)
                      startDrag(this,true
                      //this says that when you release outside the coordinates you set, the drag action stops.
                      this.stopDrag();
                      does that help?
                      • 8. Re: Stopdrag() help!
                        executing stopDrag() will stop the dragging.  there's no way to goof that up because no path/name is needed.
                        so you need to detect when you wall is hit.  ie, start a loop (or use one that's already running), check for the hittest and, if positive, execute stopDrag()
