3 Replies Latest reply on Jun 23, 2009 3:25 AM by mack_
    CFFTP error 425 can't build data connection
    Tea man
      I'm trying to have my script connect to an offsite FTP server using CFFTP tag.
      So far every CFFTP tag I use appears to fail with the possible exception of the action="open".
      The error I get is 425: Can't build data connection: No route to host.
      I can ftp using a telnet session from the same server just fine.  This is with CF8 on a Sun workstation as server (Unix).
      I have tried with and without a proxy server.
      I have tried with passive mode = yes and no.  When no the error occurs quickly.  When yes it takes about 30 seconds or more to tell me the same error.
      I have tried action = listdir and existfile and no success. I have verified the directory specified on the remote server is valid.
      I have made sure the Enable ColdFusion Security checkbox is checked. I have no idea if anything needs to be done with the sandbox stuff in the lower part of that form.
      I'm totally stumped here. My code is this:
      <cfftp connection="Myftp"
          action="Open"
          server="xxxxx"
          username="anonymous"
          password="xxxxx"
          passive="yes"
          stoponerror="Yes">
      <cfftp connection=Myftp
          action="GetCurrentDir"
          stoponerror="Yes">
      <!--- Get the current directory name --->
          action="listdir"
          directory="#cfftp.returnvalue#"
          name="dirlist"
          stoponerror="Yes">
      It fails on the last line above.  What should I try?
      What other common roadblocks can cause this?
        • 1. Re: CFFTP error 425 can't build data connection
          mack_ Level 3
          Did the FTP server recently changed IP addresses ? (I ask because Java
          caches IP addresses for a long time by default)
          Do you have the possibility to check the actual trafic ? (with tcpdump
          for example)
          Also, telnet will not show the whole picture (it makes sure that the
          initial connection to port 21 works but not that the subsequent
          connections work - ftp is a protocol that uses 2 connections: one for
          command and one for actual data transfer). Check with command line ftp
          to make sure that it works.
          Mack
          • 2. Re: CFFTP error 425 can't build data connection
            Tea man Level 1
            mack, the FTP cerser did not change IP addresses. Don't know how to use tcpdump to check the traffic.
            command line in telnet for listing a directory works fine.
            This appears to be a CF8 issue.  I can't get anyone to indicate that they can do directory listings with CFFTP on a remote server.  I'd like to confirm this is an issue with my provider (FTP Today) versus a CF8 issue with this tag.
            • 3. Re: CFFTP error 425 can't build data connection
              mack_ Level 3
              I've used CFFTP to list directory contents in the past and it worked
              so I think the problem might be specific to your setup. My bet would
              be on a passive vs active issue (a firewall rule that blocks the
              incoming request for the active mode).
              Mack
