1 Reply Latest reply on Jun 16, 2009 6:12 PM by popster
    configuring flash debugger 10 IE with FlashBuilder 4
    popster Level 1
      can any of you shed some light on getting the flash IE debugger 10 to work with FlashBuilder 4
      As of 6/17/09,
      I found the link to download the IE flash debugger at :
      http://www.adobe.com/support/flashplayer/downloads.html
      There was a link to download the IE Flash player debugger
      Download the Windows Flash Player 10 ActiveX control content debugger (for IE) (EXE, 2.03 MB)
      I've downloaded and installed the IE flash player debugger, set a couple of breakpoints in my FlashBuilder project and run in debug mode.
      I get a popup message with the following:
      Installed flash player is not a debugger
      C:\Windows\System32\Macromedia\Flash\NPSWF32.dll
      Flash builder cannot located the desired debugger version of Flash Player. You might need to install the debugger version of the Flash player or reinstall Flash Builder.
      Do you want to try to debug with the current version.
      Is there some special configuration or setup required in FlashBuilder?
