0 Replies Latest reply on Jun 16, 2009 9:27 PM by kwbarrett_jr
    Problem passing data from datefield to CFC for DB insert/update
    kwbarrett_jr Level 1
      I'm writing an admin tool in Flex with a CF and MySQL backend.  I have a simple form with a title, text, startDate, and endDate fields.  On submit, the data is passed to a function in a CFC via the remoteObject().  I am running into problems with the data from the two datefields.  Here is my form:
      <mx:Form left="0" right="0" top="0"  bottom="0">
      <mx:FormItem label="Title">
      <mx:TextInput text ="{dg.selectedItem.strTitle}" id="title"/>
      </mx:FormItem>
      <mx:FormItem label="Text" width="100%" height="75%">
      <mx:TextArea text="{dg.selectedItem.strText}" id="newstext" width="100%" height="75%"/>
      </mx:FormItem>
      <mx:FormItem label="Start Date">
      <mx:DateField selectedDate="{dg.selectedItem.dtmStart}" id="startdate"/>
      </mx:FormItem>
      <mx:FormItem label="End Date">
      <mx:DateField selectedDate="{dg.selectedItem.dtmEnd}" id="enddate"/>
      </mx:FormItem>
      </mx:Form>
      And here are my methods calling the CFC:
      <mx:Script>
      <![CDATA[
      import mx.collections.ArrayCollection;
      import mx.rpc.events.ResultEvent;
      private var isNew:Boolean = true;
      public function getNewsResult(e:ResultEvent):void{
      dg.dataProvider = e.result as ArrayCollection;
      makeNew();
      private function makeNew():void{
      title.text = "";
      newstext.text = "";
      startdate.text = "";
      enddate.text = "";
      isNew = true;
      private function save():void{
      if(isNew){
      newsRS.createNews(title.text, newstext.text, startdate.text, enddate.text);
      }else{
      newsRS.updateNews(title.text, newstext.text, startdate.text, enddate.text, dg.selectedItem.id);
      private function deleteData():void{
      if(dg.selectedIndex > -1){
      newsRS.deleteData(dg.selectedItem.id);
      </mx:Script>
      On load the retrieve() method is called to populate a datagrid.  On click, the form is populated with data corresponding to the selected grid row.  User then submits which should call the insert or update method.  I see no errors, however, no update occurs for existing records and no insert occurs.  Is there something I'm missing in my method call?  Thanks.
