0 Replies Latest reply on Jun 17, 2009 6:36 AM by raj kg
    swf is not getting loaded into HTML container in AIR
    raj kg
      I tried to load swf file into HTML container in AIR 1.5 (AS 3) but the swf file is not loaded.  The source code (in .txt format) is attached with this message.
      All images and data are getting loaded except the flash (SWF) file.  The data or the images are called from XML files as values (which are stored in the server).
      The SWF (working in stand-alone mode properly or working when inserted in a simple HTML code/page) file is not getting loaded locally (in AIR) too.
      I wanted to know whether anyone has experienced similar kind of problem, and how you solved it.
      Thanks in advance.
      - Raj
