11 Replies Latest reply on Jun 17, 2009 11:28 PM by leybniz
    Scrollbar bug in Datagrid component ?
    cho7 Level 1
      I'm having a strange behaviour of my datagrid component in my app. If I add too many columns (ie. 100 columns) at the same time, its scrollbar appear (it's ok), but the scrollbar of the parent component (ie. a panel) appears too !
      Whereas if I had, for example 1 column, then 99 just after, it works. The panel doesn't show its scrollbar.
      I wrote a sample app to reproduce the bug :
      Steps :
      1/ add one column, then another on. OK
      2/ reset, add 1000 columns -> overflow, the panel scrollbar is activated
      3/ reset, add 1, then 999 -> OK
      The limit of the overflow seems to be the size of the datagrid. As long as she has enough space, I can initialize the grid with as many column as want. If it did not have enough space, I have to initialize first with 1 column, then add the rest.
      Sorry for my english, I'm french
      And thanks for your help
      <mx:Application
      xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical" creationComplete="init()"
      <mx:Script>
      <![CDATA[
      import
      mx.controls.dataGridClasses.DataGridColumn;
      import
      mx.collections.ArrayCollection;
      private var
      columns:ArrayCollection
      private function init():void
      columns =
      new
      ArrayCollection();
      grid.columns =
      new
      Array();
      private var
      cpt:int=0;
      private function addColumns():void
      for (var
      i:int = 0; i<Number(nb.text); i++){
      cpt++;
      var col:DataGridColumn = new
      DataGridColumn(String(cpt));
      columns.addItem(col);
      grid.columns = columns.toArray();
      private function clear():void
      cpt=0;
      columns =
      new
      ArrayCollection();
      grid.columns =
      new
      Array();
      </mx:Script>
      <mx:TextInput id="nb" text="1"
      <mx:Button label="Add" click="addColumns()"
      <mx:Button label="Reset" click="clear()"
      <mx:Panel title="Datagrid test" width="50%"
      <mx:DataGrid id="grid" width="100%" horizontalScrollPolicy="auto"/>
      </mx:Panel>
      </mx:Application>
