2 Replies Latest reply on Jun 17, 2009 9:07 AM by MrRamrod
    adding a component to modify pdf via PDFL
      I have a livecycle service running, converting msword files to pdf.
      I am in the process of configuring a more complex process that will (optionally) assemble other pages onto the pdf, generates a jpg thumbnail and then (finally) assigned reader-extensions rights to the doc.
           convertFromWord -> thumbnail gen -> reader-rights
      I have some application code (acrobat plugin api / PDF library) which modifies pdf documents, adding watermarks.  I would lke to execute this step in between thumbnail generation and the reader-extensions rights are assigned. e.g.
           convertFromWord -> thumbnail gen -> watermark -> reader-rights
      How might I go about incorporating this into liveCycle?
      Is this a custom document component I can write?  Is there an existing service I can adapt?
      Do i need to write this in Java, or can i use my c++ implementation?
      I can't find any reference to any way of being able to modify a pdf within liveCycle using via the official PDF APIs, hence I am hoping someone on this forum can point me in the right direction.
      Thanks in advance
