1 Reply Latest reply on Jun 17, 2009 9:20 PM by gesrat
    Data Services - REST-ful URLs and path substitution  parameters
    gesrat
      It is common for REST-full APIs (implemented on top of HTTPService) to require URL paths to contain substitution parameters.  For example, if my service end point is defined as 'http://...../rest/users/{id}/workspaces', then it would be nice if the generated service wrapper included a parameter for the substitution values - ie "function get_userWorkspaces(id:String) : AsyncToken "
        • 1. Re: Data Services - REST-ful URLs and path substitution  parameters
          gesrat Level 1
          I found a technique to achieve this using a custom Serializer for the Service Operation that overrides the "serializeURL" method.  However due to a bug (see SDK-21872 ) the technique doesnt work in FB4 beta 1.  See code snippet below...
          package services.listeningpost
          import com.adobe.serializers.xml.XMLSerializationFilter;
          import mx.rpc.http.Operation;
          public class ListeningPost extends _Super_ListeningPost
          protected var pathParams:Object = [];
          public function setPathParam(key:String, value:String):void
          pathParams[key] = value;
          public function getPathParam(key:String):String
          return pathParams[key];
          private var _serializer:LPXMLSerializationFilter;
          public function ListeningPost()
              _serializer = new LPXMLSerializationFilter(this);
              super;
              for each(var o:Operation in this.operations){
              if (o.serializationFilter is XMLSerializationFilter)
              o.serializationFilter = _serializer;
          // Private class below provides custom Serializer
          import mx.rpc.http.AbstractOperation;
          import services.listeningpost.ListeningPost;
          class LPXMLSerializationFilter extends XMLSerializationFilter{
          private var _service:ListeningPost;
          public function LPXMLSerializationFilter(service:ListeningPost)
          super();
          _service = service;
          override public function serializeURL(operation:AbstractOperation, obj:Object, url:String) : String
          var useUrl:String = super.serializeURL(operation,obj,url);
          var keys:Array = useUrl.match(/\{([^\}]*)\}/g);
          for each(var s:String in keys){
          var r:String = _service.getPathParam(s);
          if (r != null)
          useUrl = useUrl.replace(s,r);
          return useUrl;
