I have a nightmare situation with RH7 with no clue to resolve. What are my options to fix this
I am having trouble with robohelp, selecting insert action does not display the pop up window. This prevents functions such as inserting images & files, importing files and creating hyperlinks to documents created in word, frame maker.
when I perform this action, the pop up window appears virtually but is not visible to make the selection and RH freezes.
I have to end the process or press esc to find some work around - so far none available
Please help.
Welcome to the community.
Have you recently gone from a dual monitor setup to a single monitor? When this happens, RH can sometimes keep tossing dialog boxes over where it thinks the second monitor is. I typically use a program called ForceWindowVisible (get it here) to push wandering dialogs back into view. Give that a try and see if it works. Hope this helps,
Ben
A lot of windows also allow you to"snag" the window with the following keys:
Perform your action so that the window should be in focus, e.g. Insert > Image.
Press Alt, Spacebar, M.
Press any arrow key.
Waggle the mouse around wildly until the cursor and attached window display on your screen.
Left-click to drop the window.
HTH.
We were having the same problems, and we had a good laugh when we read Amebr's suggestion, which seemed pretty crazy. But it worked! It solved several different problems we were having with both RH and other programs. Thank you!
/Eileen
Hi all,
thanks so much...I just can't believe my eyes...after a long long time, my windows are visible again.
