2 Replies Latest reply on Jun 18, 2009 1:12 AM by Dean Utian
    Adding text on a vector graphic
    IbrahimFromAustralia
      Is there a way of adding text on top of a vector graphic instead of using a standard button in Director? My intention is to attach words to a button designed as a vector graphic. Something like adding the words "Click Here" to the button. Also is there a tutorial on the net to show how to design three interactive buttons that change when the cursor is entering or clicking on them or can this only be done through a behaviour? Thanks for your help.
        • 1. Re: Adding text on a vector graphic
          Sean_Wilson Adobe Community Professional
          You could place a text sprite in the next higher channel than the vectorShape sprite in the score. Or you could use imaging lingo to combine the vectorShape member's image and the text member's image into a bitmap member.
          It is readily done in the Director environment using a behavior/script. If you want to use Flash to create (and import) buttons from there, such buttons can be created in Flash without using code and don't require any code in Director to display their various states.
          • 2. Re: Adding text on a vector graphic
            Dean Utian Adobe Community Professional
            Hi Ibrahim,
            The Library Palette has a  number of button type behaviors  - such as:
            In 'Interactive > Animation' category
            Rollover Cursor Change - as the name suggests, changes the cursor
            Rollover Member Change - switchescast members of a sorite, one when the mouse is over, the other whne it is off the sprite
            'Controls' category
            Multi-State Button
            Push Button
            The above give a few more states than available in the 'Rollover Member Change' behavior.
            Experiment with the behaviors in the library. There are some good ones in there. And they are teh easiest way to get this type of effect (as compared to writing the code yourself).
            Dean
            Director Lecturer / Consultant / Director Enthusiast
            http://www.deansdirectortutorials.com/
            http://www.multimediacreative.com.au
