1 Reply Latest reply on Jun 17, 2009 6:08 PM by Michael Borbor
    RemoteObject endpoint= vs. Flex settings
    ProjectedSurplus Level 1
      Primarily because I cannot seem to understand the CF Root Folder / Webroot / Root URL   for a non-localhost setup (ie //DevServer/ColdFusion8/wwwroot along with http://testingIP:8500/projname???????)   I have taken to using the endpoint property in RemoteObject as follows:
              <mx:RemoteObject destination="ColdFusion"
                  source="test.cfcs.QuoteService"
                      endpoint="http://174.1.159.113:8500/flex2gateway/"
                      method="getQuote"
                      arguments="{event.symbol}">
      What is the downside of this???  I assume if the CF-Flex settings are set "properly" then flex uses those to set the "endpoint" so in theory the benefit would be not having to enter endpoint in each time (in which case I actually prefer the verbiosity of the above method) but is there any other reason/benefit to either not using the endpoint OR to setting up the CF-Flex link??
