4 Replies Latest reply on Jun 18, 2009 11:14 AM by Harm Millaard
    batch capture settings do not match project settings
    Michael Kominsky
      Batch capture audio settings do not conform to project settings-
      PROJECT SETTINGS ON CREATION OF NEW PROJECT:
      For editing with IEEE1394 (FireWire/i.LINK) DV equipment.
      Standard NTSC video (4:3 interlaced).
      48kHz (16 bit) audio.
      Drop-Frame Timecode numbering.
      General
      Editing mode: DV NTSC
      Timebase: 29.97fps
      Video Settings
      Frame size: 720h 480v (0.9091)
      Frame rate: 29.97 frames/second
      Pixel Aspect Ratio: D1/DV NTSC (0.9091)
      Fields: Lower Field First
      Audio Settings
      Sample rate: 48000 samples/second
      Default Sequence
      Total video tracks: 3
      Master track type: Stereo
      Mono tracks: 0
      Please note audio setting for project 48kHz (16 bit) audio.
      When I set for batch capture by creating off-line clips using the "Log Clip" option the off-line clip shows audio as
      32KHZ 16-bit  everyting else is correct as project settings.
      Just prior to creating the off-line batch capture clip I had sucessfully captured from the same device using the same tape shot with the above settings including 48khz 16-bit audio by using standard " Capture" by setting in & out then clicking Capture>In/Out.
      I've looked at capture settings etc...unable to determine to change audio settings etc or why the audio settings under batch capture do not conform to project settings...
      Any ideas?
      Tnx,
      mick
