1 Reply Latest reply on Jun 17, 2009 9:30 PM by dsa01
    AIR won't install in some Mac OS X user accounts, but does in others
      I've been frustrated over a year with trying to get AIR installed on my laptop.  I had beta versions working at one point, but somewhere along the line all attempts to install apps resulted in the dreaded "the application could not be installed because the AIR file is damaged" error.  After months of fighting it and following instructions in the numerous threads here, I gave up.
      I'm right back where I started though.  I'm trying to install AIR and TweetDeck.  I get the AIR file is damaged message if I attempt the install in my primary user account.
      Here's the airappinstall.log:
      Starting app install of http://downloads.tweetdeck.com/TweetDeck_0_26.air
      UI SWF load is complete
      UI initialized
      failed while unpackaging: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Error #2014" errorID=2014]
      starting cleanup of temporary files
      application installer exiting
      Here's the airinstall.log:
      stateRunningAppInstaller: appinstaller -runtime "/var/folders/CO/COLPFwJZGACYWWjy3XA3NE+++TI/-Tmp-/airqfNqKN/Adobe AIR Installer.app/Contents/Frameworks" -playerVersion=10,0,22,87 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://downloads.tweetdeck.com/TweetDeck_0_26.air
      App installer failed; exit code 7
      begin quitting
      Interestingly, if I log into the Admin account on the Mac, I am able to install and run TweetDeck.  I installed in that account with no problems, but when I go back to my user account the app appears in my /Applications directory, but starting it up just opens the AIR installer which stalls and has to be force-quit to exit it.  The log files show no entries.
      I've uninstalled and reinstalled AIR a dozen times.  Fixed permissions, deleted the /var/folders/zz folder & rebooted, deleted all certificates in the keychain.
      This is driving me nuts.
      Any suggestions please, and before suggesting, that I uninstall, fix permissions, delete /var/folders/zz, check the keychain, please note that I've already done that.  ;-)
      Any ideas?
