4 Replies Latest reply on Jun 18, 2009 5:24 AM by dzeikei
    Get hostname
    greatshri
      Dear All,
      Thanks in advance.
      I want a script in flex which will fetch the host name form url.
      I have some scripts but it fetched the host name from the host the swf is hosted.
      Let me explain.
      I have my site on  www.mysite.com which embeds a flex swf.
      I have hosted it on another server say.. www.myotherserver.com/assets/flash/app.swf
      I want a script in flex which fetched the host name at runtime.
      Hope this make sense.
      Thanks.
        • 1. Re: Get hostname
          leybniz Level 4
            import mx.core.Application;
            import mx.utils.URLUtil;
            public static const DYNAMIC_MARKER:String = '[[DYNAMIC]]';
            public static function appContextUrl(includeFolder:Boolean = true):String {
             var url:String = Application.application.url;
             var protocol:String = URLUtil.getProtocol(url);
             var domain:String = URLUtil.getServerNameWithPort(url);
             if (protocol == 'file')
              return 'http://localhost/';
             var folder:String = url.replace(protocol + '://' + domain, '');
             folder = folder.slice(0, folder.lastIndexOf('/'));
             // Cut DYNAMIC_MARKER if App built using RSL's
             if (folder.indexOf(DYNAMIC_MARKER) >= 0) {
              folder = folder.slice(0, folder.lastIndexOf(DYNAMIC_MARKER) - 1);
              // cut swf module name
             if (!includeFolder)
              folder = '';
             return protocol + '://' + domain + folder + '/';
          If you feel this message answers your question or helps, please mark it respectively
          • 2. Re: Get hostname
            greatshri Level 1
            Thank You ,
            Alexander Mazuruk
            But your script give me the host name of the server where my swf files are loaded and not from the browser url.
            Thank you.
            • 3. Re: Get hostname
              leybniz Level 4
              BrowserManager.getInstance().url
              • 4. Re: Get hostname
                dzeikei Level 2
                I believe you are looking for
                BrowserManager.getInstance().base
