5 Replies Latest reply on Jun 18, 2009 1:02 PM by kglad
    Stop movieclip
    chewbears
      // Flash8 code
      import flash.display.BitmapData;
      import flash.filters.GlowFilter;
      var maxBoltThickness:Number = 5;
      var boltHeight:Number = 400;
      var maxSplitsPerBolt:Number = 1;
      function firstLight() {
      // remove old bolt and create init bolt
      _root.lightning.removeMovieClip();
      newBolt(_root, 0, 0);
      // apply a filter for metal bluish light effect
      _root.lightning.filters = new Array(new GlowFilter(0xBBBBFF, 100, 13, 13, 3, 4));
      // function for onEnterFrame
      function lightgrow() {
      this.y += 7;
      this.x += Math.random()*18-9+this.tendenz;
      // randomly split the bolt
      if (Math.random()*4-2>1.9 && this.splits>0) {
      this.splits--;
      newBolt(this, this.x, this.y);
      // get thinner the closer it gets to the ground
      thickness = _root.maxBoltThickness-this.y/_root.boltHeight*_root.maxBoltThickness;
      this.lineStyle(thickness, 0xFFFFFF);
      this.lineTo(this.x, this.y);
      if (this.y>_root.boltHeight) {
      this.onEnterFrame = null;
      if (this == _root.lightning) {
      _root.firstLight();
      // create a new bolt
      function newBolt(where:MovieClip, x:Number, y:Number) {
      var light:MovieClip = where.createEmptyMovieClip("lightning", where.getNextHighestDepth());
      if (where == _root) {
      light._x = Math.random()*200+150;
      light.splits = _root.maxSplitsPerBolt;
      light.x = x;
      light.y = y;
      light.thickness = 0;
      light.tendenz = Math.random()*14-7;
      light.moveTo(x, y);
      light.onEnterFrame = lightgrow;
      // initialize
      firstLight();
      I can not make the above stop when the root moves on to frame 2.
        • 1. Re: Stop movieclip
          try:
          chewbears wrote:
          // Flash8 code
          this.y += 7;
          this.splits--;
          _root.firstLight();
          light = where.createEmptyMovieClip("lightning", where.getNextHighestDepth());
          light.x = x;
          light.y = y;
          light.moveTo(x, y);
          // initialize
          firstLight();
          // call to stop
          funtion stopF(){
          light.onEnterFrame=null;
          light.removeMovieClip();
          • 2. Re: Stop movieclip
            chewbears Level 1
            kglad I think I messed up.  I don't want to "stop" it but pause it.  So basically when the frame finishs I want to pause where the bolt is for a moment and then I will use
            on the next frame to delete it.
            So how would I place a pause in it? on the next frame.
            An aside what is controling the speed of the line being drawn.
            • 3. Re: Stop movieclip
              this will toggle pause and play:
              if(!this.toggle){
              } else {
              light.onEnterFrame=lightgrow;
              this.toggle=!this.toggle;
              the speed is controlled by the framerate and this line:
              this.y += 7;
              • 4. Re: Stop movieclip
                chewbears Level 1
                Kglad thanks for the response very helpful, but I don't want a play/pause just a pause.
                Frame 1 = plays introduction, while it plays lighnting moves
                Frame 2 = pause to highlight the last position of the lightning
                frame 3 = delet movie clip and enter website.
                So the pause I am looking for would be coded in frame 2 of the root.
                thanks
                • 5. Re: Stop movieclip
                  // pause
                  // play
