1 Reply Latest reply on Jun 18, 2009 12:30 PM by Mark E. Shepherd
    What Frame Rate does Catalyst export .SWF at?
    WOLFTEST09
      When I import a SWF file from Catalyst into another flash program, won't display never mind play, the error I get is that the frame rates don't match,
      therefore I need to know what  frame rate it exports at?
        • 1. Re: What Frame Rate does Catalyst export .SWF at?
          Mark E. Shepherd Adobe Employee
          If you have a SWF created by Catalyst, and you're using that SWF in something you're creating with Flash Builder or Flash Pro, then I think frame rate shouldn't matter. But maybe if you can give more details I could help more... Which flash program are you importing the SWF into, what commands or code are you using to do the import? Is there an error message or alert, if so what does it say? Any info you can provide will be helpful.
