0 Replies Latest reply on Jun 18, 2009 11:00 AM by mar808
    doc crashes on close
    mar808
      Ok;
           I have a very simple javascript on document level that is causing the pdf doc to crash when it is closed:
      function show() {
          console.show();
          console.clear();
          var aMy3DAnnots = getAnnots3D(0);
          var c3d = aMy3DAnnots[0].context3D;
          this.timer = new c3d.TimeEventHandler();
          this.timer.onEvent = function(event) {
              console.println("ok");
          c3d.runtime.addEventHandler(this.timer);
         Then I have a simple button that has a single line javascript:
      show();
           The function executes correctly and shows "ok" in the console as expected. The problem is when I try closing the document it provides an exception error and the pdf crashes. By the way, in the annotation3d i have a simple cube u3d object.I also tried to put the entire script in the same button but it is also crashing.
           Can someone please help?
