3 Replies Latest reply on Jul 14, 2010 2:49 PM by develascof
    Help with Director 11.5 crashing on silent install
    redrong
      I generate the install.xml and uninstall.xml which i place in the deploy folder.  I create the Application.xml.override and place it in the appropriate folder. I can successfully install and uninstall the Adobe Director 11.5 silently.  However, when i start up the Director and do a few thing, i get a fatal error followed by memory max out.  I have check the requirement and all my test system exceed 512mb of ram and more than 500 mb. This occur on any machine i tried.  Using the same source and removing the Application.xml.override file, i can install the application normally and run the application with no problem. Any idea?
      <Configuration>
      <Payload>
      <Data key="Serial" protected="0">xxxxxxxxxxxxxxxxxxxxxx</Data>
      <Data key="Registration">Suppress</Data>
      <Data key="EULA">Suppress</Data>
      <Data key="Updates">Suppress</Data>
      </Payload>
      </Configuration>
