1 Reply Latest reply on Jun 18, 2009 10:32 PM by Gregory Lafrance
    how to get object attribute by string attribute name?
    powerlevel500?Impossible
      Hi
      I'm trying to get an object attribute from my created object via a string.
      For example
      var obj:Object = new Object;
      obj.param1 = "hello"
      obj.param2 = "world"
      obviously I can get the params by going
      str:String = obj.param1;
      however I'd like to get tit by a string. e.g:
      findingStr:String = "param1"
      str:String = obj.[findingStr]; //some syntax to get the attribute out
      I know you can detect if the object has the attribute by a string, but can someone please tell me how to reference the attribute by the string?
      Thanks!
        • 1. Re: how to get object attribute by string attribute name?
          Gregory Lafrance Level 6
          This seems to do the trick:
          <?xml version="1.0"?>
          <mx:Application
           xmlns:mx="http://www.adobe.com/2006/mxml"creationComplete="init();"
          <mx:Script>
          <![CDATA[
          private function init():void{
          var obj:Object = new Object;obj.param1 =
          "hello";obj.param2 =
          "world";
          var findingStr:String = "param1"
          var str:String = obj[findingStr]; txt.text = str;
          </mx:Script>
          <mx:TextArea id="txt"/></mx:Application>
          If this post answers your question or helps, please mark it as such.
