0 Replies Latest reply on Jun 19, 2009 3:01 AM by karthik flex
    Read xml to datagrid?
    karthik flex Level 1
      hi guys
      i have some doubt i have one xml
      <root>
      <data>
      <time datas="Hello">
      <john second="Karthikkkkkkkkk"></john>
      </time>
      </data>
      </root>
      can i make "datas" as header text and "second" as cell data in datagrid
      private function handleResult(event:ResultEvent):void
           xmlResult = XML(event.result);
           callLater(initApp);
      public function initApp():void
          _xlcCatalog = new XMLListCollection(xmlResult.data);
          buildDG();
      private function buildDG():void
          var aColumnDef:Array = getColumnDefArray();
          var oColumnDef:Object;
          var dgc:DataGridColumn;
          var aColumnsNew:Array = dg.columns
          var iTotalDGWidth:int = 0;
          for (var i:int=0;i<aColumnDef.length;i++)
            oColumnDef = aColumnDef[i];
            dgc = new DataGridColumn();
            dgc.dataField = oColumnDef.dataField;
            dgc.width = oColumnDef.width;
            iTotalDGWidth += dgc.width;
            dgc.editable = oColumnDef.editable;
            dgc.sortable = oColumnDef.sortable
            dgc.visible = oColumnDef.visible;
            dgc.wordWrap = oColumnDef.wordWrap;
            aColumnsNew.push(dgc)
         // dg.draggableColumns=false;
         // dg.resizableColumns=false;
          dg.editable=true;
          dg.columns = aColumnsNew;
          dg.editable = true;
          dg.width = iTotalDGWidth;
          dg.rowCount=_xlcCatalog.length;
         // trace("_xlcCatalog ",_xlcCatalog.length);
          dg.dataProvider = _xlcCatalog;
          this.addChild(dg);
      private function getColumnDefArray():Array
      //  Alert.show("colcount:" + _xlcCatalog.toXMLString());
          var aColumns:Array = new Array();
          var node0:XML = xmlResult.data[0];
          trace(xmlResult);
          var xlColumns:XMLList = node0.children();
          var xmlColumn:XML;
          for (var i:int=0;i<xlColumns.length();i++)  {
            xmlColumn = xlColumns[i];
            oColumnDef = new Object();
            oColumnDef.dataField = xmlColumn.localName();
            switch (oColumnDef.dataField)  {
                /* case "time":
                  oColumnDef.width = 80;
                oColumnDef.sortable = false;
                oColumnDef.visible = true;
                oColumnDef.editable = false;
                oColumnDef.wordWrap = true;
                break; */
              default:
                oColumnDef.width = 150;
                oColumnDef.sortable = true;
                break;
            aColumns.push(oColumnDef);
          return aColumns;
      if i change oColumnDef.dataField = xmlColumn.localName(); (it is taking the node name e.g time, john)  but when   to oColumnDef.dataField = xmlColumn.attribute();   it is taking the node attributes(eg Hello, Karthikkkkkkkkk) but not displaying one below the other
      any idea
      karthik.k
