2 Replies Latest reply on Jun 19, 2009 7:55 AM by iLaible
    PDF Versions of Documents and  Adobe Reader Versions
    iLaible
      hello
      ist there a overview table, which shows the details and compatibility of PDF File Versions and Adope Reader
      of is it easy to say
      PDF1.3 need Adobe Reader 4.0 and higher
      PDF1.4              5.0
      PDF1.5              6.0
      PDF1.6              7.0
      PDF1.7              8.0
      thanks for the answer where i could find an overview table
      if there is a backward compatibility
      reading PDF1.7 with Adobe Reader 5.0
      maybe additional table which function are compatible
      and which are not supported or create errors by using old Reader with new Documents.
      hope you have some answers, thanks
      and best regards
      Laible
        • 1. Re: PDF Versions of Documents and  Adobe Reader Versions
          MichaelKazlow MVP & Adobe Community Professional
          You cannot reliably read newer versions of pdf with older versions. We cannot provide a table, because it depends upon the features used by the file. For example you can usually take a pdf raster image that is saved in an newer format, with an older version. You'll get an error message, but it usually will open. However, if you use a pdf that uses newer security features, it will NEVER open.
          • 2. Re: PDF Versions of Documents and  Adobe Reader Versions
            iLaible Level 1
            Hello Adobe Team
            thanks for the fast answer regarding my question in your forum
            have a nice weekend
            best regards from switzerland
            Ingo Laible
            Development Embedded
            R+D Hardware Engineer
            Endress+Hauser Process Solutions AG
            Kaegenstrasse 2
            CH-4153 Reinach
            Switzerland
            Phone:  +41 61 715 73 28
            Fax:      +41 61 715 28 04
            E-Mail:     ingo.laible@solutions.endress.com
            Web:  www.process-solutions.endress.com
