5 Replies Latest reply on Jun 21, 2009 1:01 AM by *Prashant Shelke*
    CheckBox group
    Zolotoj Level 3
      Anything is available?
        • 1. Re: CheckBox group
          leybniz Level 4
          nope, and may I ask you what functionality are you expecting from this kind of container?
          probably you should go with the regular mx:Box?
          • 2. Re: CheckBox group
            Zolotoj Level 3
            I would say it should be a class with programmable numbers of checkboxes and their properties, and a method that will return an array or something with selected values.
            • 3. Re: CheckBox group
              leybniz Level 4
              I see, thanks, this way you'll have to relay on yourself only
              or you could take a look on that one
              http://robsondesign.com/blog/index.php/2008/12/23/checkboxgroup-20-beta/
              • 4. Re: CheckBox group
                Zolotoj Level 3
                I have put something together very quick. In case others need it:
                package
                import flash.events.Event;
                import mx.containers.HBox;
                import spark.components.CheckBox;
                public class checkBoxGroup extends HBox{
                public var checkBoxNumber:int = 0;
                private var chkBox:CheckBox;
                private var _dataProvider:Object;
                public function checkBoxGroup(){
                super();}
                override protected function createChildren():void{
                // add as many checkboxes as developer has set via checkBoxNumber
                for (var i:int=0;i<checkBoxNumber;i++){
                chkBox =
                new CheckBox();chkBox.name = i.toString();
                chkBox.addEventListener(
                "change", onClick);addChild(chkBox);
                validateNow();
                public function set dataProvider(dataObj:Object):void{
                _dataProvider = dataObj;
                CheckBox(getChildAt(i)).selected = Boolean(Number(dataObj[i].selected));
                CheckBox(getChildAt(i)).label = dataObj[i].label.toString();
                public function get dataProvider():Object{
                return _dataProvider;}
                //called by click of the checkbox
                private function onClick(event:Event):void{
                //set the checkbox state into the dataProviderdataProvider[Number(event.target.name)].selected = String(event.target.selected);
                 modulecode{
                implementation:
                <modulecode:checkBoxGroup
                checkBoxNumber="4"/>
                data structure:
                <?xml version = "1.0" encoding="Windows-1252" standalone="yes"?>
                <VFPData>
                <customertype>
                  <id>1</id>
                  <label>RETAIL</label>
                  <selected>0</selected>
                </customertype>
                <customertype>
                  <id>2</id>
                  <label>CATALOG</label>
                </customertype>
                <customertype>
                  <id>3</id>
                  <label>HOSPITALITY</label>
                </customertype>
                <customertype>
                  <id>4</id>
                  <label>WEB</label>
                </customertype>
                </VFPData>
