1. Re: Connecting to the RH Server - Additional Security?
RoboColum(n) Jun 19, 2009 9:36 AM (in response to RoboColum(n))OK people you can all stand down as I have managed to figure out what was wrong. The "Server Name" path in my publish destination was missing one vital element. The should should be "<servername>:<port>/robohelp/server". For example if your server is called helpserver and you use port 8080 (it is recommended you do) the path would be "helpsever:8080/robohelp/server". I was missing the "server" off the end. Incidently there is an excellent discussion here with tons of useful information on the set-up and merged projects.
So now I have a successfully created and published project to test with the application. All I need to do now is merge 10 other help files and add context sensitive help. But enough already. Time to go home, have a beer and recharge for Monday. Thanks to Tulika, John, Peter, Kristan and others for the excellent resource mentioned above. Have a great weekend all.
Read the RoboColum(n) for mutterings on RoboHelp, Technical Communication Suite and technical communication.
