5 Replies Latest reply on Jun 23, 2009 10:41 AM by Jedi-1
    Internal Error on Startup
    Jedi-1 Level 1
      I am using Web Premium CS4 and I have been using Fireworks CS4 for over 3 months now. Today, on startup of Fireworks I get the message "internal Error" after the splash screen and I cannot do anything else or even close fireworks.
      Does any one have a remedy?
        • 1. Re: Internal Error on Startup
          heathrowe Most Valuable Participant
          Do you have the latest update installed?
          Get it here - Fireworks CS4 10.0.3 updater
          h
          • 2. Re: Internal Error on Startup
            Nadia-P Level 5
            You could try:
            Restoring default preferences
            Quit Fireworks.
            Locate the Fireworks  Preferences file on your hard disk and delete it.
            The exact location of this file varies from system to system.
            In Windows, preferences are      in your user-specific Fireworks configuration folder.
            Windows [Drive]:\Documents and Settings\[UserName]\Application Data\Adobe\Fireworks CS#\English\
            In Mac OS, preferences are in   the Library/Preferences folder in your user folder. For information about      locating your Mac OS user folder, see Apple Help.
            Mac  [User]/Library/Preferences/Adobe Fireworks CS#/en/Fireworks Preferences
            Note: On Mac OS, most  Fireworks user-specific configuration files are stored in your   user-specific Application Support folder.
                      The Fireworks CS4 Preferences file is an exception.
            Restart Fireworks.The next time Fireworks is launched, a new preferences   file will be created that restores Fireworks to its original   configuration.
            • 3. Re: Internal Error on Startup
              Jedi-1 Level 1
              Thanks all, but I have tried the deleting the preferences file. I have applied both the Air updates and the Windows CS4 updates and I still get the same internal error message on startup. I also cannot close the error message box or exit fireworks without alt cntrl delete.
              Any other ideas?
              • 4. Re: Internal Error on Startup
                Nadia-P Level 5
                No, sorry I'm out of ideas - generally trashing the preference folder brings everything back into line.
                I found this technote
                http://kb2.adobe.com/cps/405/kb405612.html
                All I can suggeset is going through the steps and nothing helps, then the last resort would be to contact Adobe Support.
                Nadia
                Adobe® Community Expert : Dreamweaver
                http://twitter.com/nadiap
                Unique CSS Templates |Tutorials |SEO Articles
                http://www.DreamweaverResources.com
                http://csstemplates.com.au/
                • 5. Re: Internal Error on Startup
                  Jedi-1 Level 1
                  Thanks, I went back and deleted both files the preferences.txt and the prefs.xml and then reopened FireWorks and it opened ok. I'll let you know if it fails again or if this didn't work.
                  Thanks again
                  Date: Tue, 23 Jun 2009 07:14:23 -0600
                  To: jediyoung@hotmail.com
                  Subject: Internal Error on Startup
                  Nadia
