3 Replies Latest reply on Jun 22, 2010 9:51 AM by the_apple
    making the 7.1.3 update silent
    rpettigr
      I am working with a client whio is still on 7.1.0 and I cannot get the 7.1.3 update to run silently or unattended.  /q /qn /quiet /passive any switch added to the msiexec other than /p adberdr713upd_all_incr.msp causes the patch to start to run then quit without installing. I do not want the users to have to click on anything to do with the update.  I am trying to wrap the install in a wise installer wrapper to push out silently with altiris.
      Has anyone had any luck with getting the patch to run silently?
      Thanks for your help and suggestions
      Ron
        • 1. Re: making the 7.1.3 update silent
          soberoi Level 1
          Hi, try these commands for silent install. But make sure that you are installing from the 7.1.2 eles you'll have to chain the patches and run through command line.
          msiexec /p <patch.msp> /qn --- silent install
          msiexec /p <patch.msp> /qb – progress bar install
          Hope this helps!!
          • 2. Re: making the 7.1.3 update silent
            rpettigr Level 1
            Thanks for the suggestions.  Those are the switches I amusing. If I run the command  from the cmd prompt it works as expected.  If I run it from inside the wise wrapper it does not work unless I only use the following command line  "msiexec /P <patch.msp>"  I suspect I am doing something wrong inside the wrapper or more people would be seeing this issue with the update. so I will keep plugging away at it.
            Ron
            • 3. Re: making the 7.1.3 update silent
              the_apple
              I am having problems installing AdbeRdr709_en_US.exe with the silent install.
              I have tried many times. This will install it but someone would have to click Next at every pop-up.
              This will install it but someone would have to click Next at every step.
              \\Path\To\Executable\AdbeRdr_en_US.exe /S/v/qn
              How can I fix this?
