0 Replies Latest reply on Jun 19, 2009 4:37 PM by Flex harUI
    [svn:fx-trunk] 8023: Frame1 cleanup part 2 (final part AFAIK).
    Flex harUI Adobe Employee
      Revision: 8023
      Author:   aharui@adobe.com
      Date:     2009-06-19 16:37:02 -0700 (Fri, 19 Jun 2009)
      Log Message:
      Frame1 cleanup part 2 (final part AFAIK).  MarshallPLan (now MarshallingSupport) is now opt-in.  All SWFs using Marshalling must use -includes=mx.managers.systemClasses.MarshallingSupport on the command line.
      QE Notes: None
      Doc Notes: None
      Bugs: N/A
      Reviewer: Joan cyclone
      tests: checkintests mustella/MarshallPlan
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/FrameworkClasses.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/CursorManagerImpl.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/DragManagerImpl.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/FocusManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/PopUpManagerImpl.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/SystemManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/SystemManagerProxy.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/ToolTipManagerImpl.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/systemClasses/ActiveWindowMa nager.as
      Added Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/systemClasses/MarshallingSup port.as
      Removed Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/systemClasses/MarshallPlan.a s
