• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Creating new folder ripple effect in other folders
Guest
Jun 19, 2009 Jun 19, 2009
I was in the RoboHelp 7 Project Manager pod. The HTML Files (Topics) folder was highlighted. I right-clicked and selected New > Folder.
I named the new folder Assets and pressed Enter to create the folder. All on its own, RH created an Assets folder under the Images, Multimedia, Style Sheets, and Baggage Files folders.
Not only that, but every folder I created under the Assets folder was also duplicated under the  Images, Multimedia, Style Sheets, and Baggage Files folders. AND, if I try then to delete one of those folders, either a.) the Delete option is not available on the right-click menu or b.) When it is available and I select it, ALL instances of the folder are deleted.
Why did RH create multiple Assets folders and why can't I create a single folder under only the HTML Files (Topics) folder?
Views
458
Translate
Translate
Report
Report
Community guidelines
community guidelines
Valorous Hero ,
LATEST
Hi there
This is perfectly normal. You need to understand that the Project Manager is simply RoboHelp's way of organizing the different project assets. Think of it as perhaps "filters" that are only showing you files that are used. For example, when you look at the files and folders of the project in Windows Explorer, you will never see a folder named "Baggage Files" or "Style Sheets". And if you create a folder, even though you see it in Baggage Files, Images, Cascading Style Sheets and HTML Topics, it's only on your hard drive once.
Hopefully this helps... Rick
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
