0 Replies Latest reply on Jun 19, 2009 6:10 PM by Evtim Georgiev (Adobe)
    [svn:fx-trunk] 8031: Scrub the TODOs in the framework, convert to FIXMEs in the new convention and assigning an owner.
    Evtim Georgiev (Adobe) Level 2
      Revision: 8031
      Author:   egeorgie@adobe.com
      Date:     2009-06-19 18:10:03 -0700 (Fri, 19 Jun 2009)
      Log Message:
      Doc Notes: N/A
      Bugs: N/A
      Reviewer: Deepa
      tests: build, checkintests
      Modified Paths:
          flex/sdk/trunk/development/eclipse/flex/flex4test/src/layouts/WheelLayout.as
          flex/sdk/trunk/frameworks/projects/flash-integration/src/mx/flash/UIMovieClip.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/DataGroup.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/DropDownList.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/Group.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/HSlider.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/List.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/PopUpAnchor.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/SkinnableContainer.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/SkinnableDataContainer.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/Spinner.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/VSlider.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/VideoPlayer.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/mediaClasses/StreamingVideo Source.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/mediaClasses/VolumeBar.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/DropDownCont roller.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/GroupBase.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/ListBase.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/ScrollBar.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/SkinnableCom ponent.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/Slider.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/ToggleButton Base.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AddAction.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimateTransform.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/Move.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/RemoveAction.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/Rotate.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/Scale.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/animation/Animation.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/animation/MotionPath.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/animation/Timeline.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/AddActionInstan ce.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/AnimateInstance .as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/AnimateTransfor mInstance.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/AnimateTransiti onShaderInstance.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/FadeInstance.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/MoveInstance.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/RemoveActionIns tance.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/layouts/HorizontalLayout.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/layouts/VerticalLayout.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/layouts/supportClasses/LayoutElementHe lper.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/Path.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/Rect.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/RichEditableText.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/SimpleText.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/pathSegments/LineSegment.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/supportClasses/GraphicEleme nt.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/supportClasses/StrokedEleme nt.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/supportClasses/TextGraphicE lement.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/spark/ErrorSkin.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/spark/FocusSkin.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/utils/BitmapUtil.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/collections/ModifiedCollectionView.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/DataGrid.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/DateChooser.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/List.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ProgressBar.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/ListBase.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Container.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/CompositeEffect.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/Effect.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/EffectTargetFilter.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/PropertyChanges .as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/SequenceInstanc e.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/geom/Transform.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/CursorManagerImpl.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/FocusManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/SystemManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleProtoChain.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/utils/MatrixUtil.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/utils/ObjectUtil.as
