0 Replies Latest reply on Jun 19, 2009 7:26 PM by Peter Farland
    [svn:fx-3.x] 8033: Adding a work around for web services that make use of complex type extensions but do not return properties in the expected sequence order .
    Peter Farland Level 3
      Revision: 8033
      Author:   pfarland@adobe.com
      Date:     2009-06-19 19:04:57 -0700 (Fri, 19 Jun 2009)
      Log Message:
      Adding a work around for web services that make use of complex type extensions but do not return properties in the expected sequence order. We now search for extension properties in any sequence.
      QE: Yes, please add a test case that returns a type hierarchy of complexTypes using extension.
      Doc: No
      Checkintests: Pass
      flexunit: feature webService Pass
      Reviewer: Svetlin to review
      Bugs:
      SDK-15465 - WebService class SDK 3 not working against JIRA wsdl while it did in SDK 2 hf 3
      SDK-16891 - WebService call returns partially-populated objects
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-15465
          http://bugs.adobe.com/jira/browse/SDK-16891
      Modified Paths:
          flex/sdk/branches/3.x/frameworks/projects/rpc/src/mx/rpc/xml/DecodingContext.as
          flex/sdk/branches/3.x/frameworks/projects/rpc/src/mx/rpc/xml/XMLDecoder.as
