0 Replies Latest reply on Jun 19, 2009 8:15 PM by deepa subramaniam (adobe)
    [svn:fx-trunk] 8020: Fallout from PARB changes - addressing 3 issues:
    deepa subramaniam (adobe) Level 2
      Revision: 8020
      Author:   dsubrama@adobe.com
      Date:     2009-06-19 16:02:54 -0700 (Fri, 19 Jun 2009)
      Log Message:
      1.) http://bugs.adobe.com/jira/browse/SDK-21873 - Fixed
      2.) missed PARB requested change, adjustSelectedIndex()/adjustSelectedIndices() are collapsed into a single method, adjustSelection()
      3.) Excellent catch from Evtim - selectedIndices is now a Vector of ints instead of a Vector of Numbers (the PARB rename list had the right change!). Selection indices are always non-fractional, so we can get a slight savings by making this a Vector of ints.
      QA: Yes - you'll need to update tests for point #3, and if you worked off the PARB rename list, then you shouldn't have to update for #2, otherwise you do.
      Doc: Yes
      Checkintests: Pass, as well as List/DDL mustella tests (except for 11 List tests that need selectedIndices to be changed from Vector.)
      Reviewer: Evtim
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/List.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/ListBase.as
