3 Replies Latest reply on Sep 26, 2008 9:41 PM by g-s-b
    Dependant & Independant Variable Relationship
    masita18 Level 1
      Would like know if we have relationship between object variables, what datatype would be most suitable?
      Eg. Object A is the cause variable, object B is the affected variable and object C is also the affected variable. Thus object A, B and C has dependent and independent relationship, which datatype should we use so that these relationship could be captured (will not be using database).
      The number of object variable may varies, depending on how many object variable the user wants to create. Each object variable contains few properties such as image, slider, name. And base on the dependent or independent relationship, each object variable slider will need to change correspondingly.
