3 Replies Latest reply on Jun 21, 2009 7:07 AM by Ramon F Herrera
    How to modify the "Border Color" property of a Radio Button?
    Ramon F Herrera Level 1
      How do I modify the "Border Color" property of a Radio Button?
      TIA,
      -RFH
        • 1. Re: How to modify the "Border Color" property of a Radio Button?
          I found out that I can make the border of the radio button appear/disappear like this:
            radioButton.strokeColor = color.transparent;
            radioButton.strokeColor = color.black;
          However, I still have one problem: I would like the filled black circle in the middle to be always invisible/transparent as well.
          I tried this, but it is not allowed:
            radioButton.textColor = color.transparent;
          In essence, what I am trying to do is implement a circling tool in which only the outside circle is seen.
          TIA,
          -RFH
          • 2. Re: How to modify the "Border Color" property of a Radio Button?
            What's the point of a radio button if you can't see if it's checked or not?
            If you want a circling tool I suggest you use something else. Maybe an annotation.
            • 3. Re: How to modify the "Border Color" property of a Radio Button?
              This is copy & pasted from another forum.
              - Ramon
              Is it possible to have a completely invisible Check Box?
              How can I create an invisible set of Check Boxes?
              The only feature I need is the ability to detect clicks on them, I will program my own visual part. What I am trying to implement is a circling tool.
              Let's say that a form contains the weekdays:
                   Sun  Mon  Tue  Wed  Thu  Fri  Sat
              I would like to place 7 invisible check marks on the days and set {hidden|visible} property on the 7 pre-drawn circles.
              TIA,
              -Ramon
              Re: Is it possible to have a completely invisible Check Box?
              Rather than checkboxes, I would do buttons with an blank appearance that you can then switch to a circle with setButtonIcon().
              Re:
                  S  M  T  W  Th F  S
              Leonard,
              I implemented a preliminary version of the constrained circling tool, based on your non-appearance button suggestion. Now I realize, however, that a real set of Check Box/Radio Button provides me with more than a plain rectangle that detects clicks.
              - I need the ability to navigate through the fields by pressing TAB - This is provided.
              - I need the ability to check/uncheck by pressing SPACE - This is not provided.
              But, more importantly: I need the ability to automatically fill the forms, and this will require some additional coding making it more expensive/complex.
              Therefore, I reopen my question about finding a way(s) to make a little customization to the Radio Button widget.
              All is need is to make the central filled circle disappear, plus some of the border circles (for W and Th) have to be larger.
              -Ramon
