3 Replies Latest reply on Jun 21, 2010 2:21 AM by BBCLX
    Detecting Mac command key
    SilentChris Level 1
      Is there a way in AIR currently to detect when a user is using the command modifier key on a mac?  Detecting control and shift seem to work fine, but KeyboardEvent.commandKey is always false.
      I noticed under the flash.ui.Keyboard class, the COMMAND constant has the note: " This constant is currently only used for setting menu key equivalents."  Does that mean that AIR doesn't support detecting the command modifier key as part of a KeyboardEvent?
        • 1. Re: Detecting Mac command key
          Joe ... Ward Level 4
          The KeyboardEvent.commandKey property works correctly for me.
          • 2. Re: Detecting Mac command key
            SilentChris Level 1
            Ahh - apparently the command key can be detected on a keyDown event, but not on a keyUp event (although the ctrlKey detection seems to work on keyUp).  Changing the handler to keyDown worked for me.  Example app below:
            <mx:WindowedApplication xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
                <mx:Canvas x="10" y="10" width="782" height="410" backgroundColor="#CCCCCC">
                    <mx:TextInput keyDown="handleKeyDown(event)" keyUp="handleKeyUp(event)" x="10" y="378" width="762"/>
                    <mx:VBox id="key_infos" x="10" y="10" width="400">
                    </mx:VBox>
                </mx:Canvas>
                <mx:Script>
                    <![CDATA[
                        import mx.controls.Label;
                        internal function handleKeyDown(e:KeyboardEvent):void {
                            if (e.commandKey) {
                                var l:Label = new Label();
                                l.text = 'key down - holding cmd key';
                                key_infos.addChild(l);
                        internal function handleKeyUp(e:KeyboardEvent):void {
                            if (e.commandKey) {
                                l.text = 'key up - holding cmd key';
                </mx:Script>
            </mx:WindowedApplication>
            • 3. Re: Detecting Mac command key
              BBCLX Level 1
              I could make it work on OSX, but not on Windows, where I get a strange behaviour: http://forums.adobe.com/message/2718032#2718032
              Please help.
