1 Reply Latest reply on Jun 22, 2009 4:27 AM by Richard_Abbott
    Is there a way to write files on server without a server-side script?
    asbondar
      Hi
      I have a "big" question. I want to know if it's possible to write files on a server without a server-side script directly from flex. I need to change the content of an xml file on the server directly from flex.
      If anybody can help me that will be great.
      Thanks.
        • 1. Re: Is there a way to write files on server without a server-side script?
          Richard_Abbott
          asbondar,
          the simple answer is no - to do stuff on the server you must have code that runs on the server. However, you may well be able to tap into pre-existing frameworks for doing this which minimise the amount of code you have to write. My personal recommendation would be to take the time to get to grips with server-side coding, as there are lots of benefits to this outside the immediate problem you have, but maybe the time constraints don't allow this,
          Richard
