1 Reply Latest reply on Sep 25, 2008 4:39 PM by JoeDaSilva
    Fonts anti-aliasing not matching
      I am creating a menu header for a site, and within the menu there is a pop-up menu. The font I am using for the menus is Verdana...however the anti-aliasing is not matching. The anti-aliasing for the pop-up menu text is very small, the text appears very sharp and clear. The font on the main menu does not match, regardless of the anti-aliasing setting I use. Has anyone had this issue before, and if so, what did you do?
        • 1. Re: Fonts anti-aliasing not matching
          JoeDaSilva Level 4
          I'm speculating here, but chances are the text in main button area is abiding by whatever anti-aliasing setting you've set in Fireworks, and will be rendered as a graphic once you export the menu. The pop-up portion of the menu will be rendered as html/css (ie: not a graphic) and will therefor only be anti-aliased if the end user employs OS specific AA (ie:cleartype).
          Make sense?
