0 Replies Latest reply on Jun 22, 2009 10:02 AM by Chet Haase
    [svn:fx-trunk] 8044: Final (!) PARB changes for effects.
    Chet Haase Level 3
      Revision: 8044
      Author:   chaase@adobe.com
      Date:     2009-06-22 10:01:54 -0700 (Mon, 22 Jun 2009)
      Log Message:
      Final PARB changes for effects.
      - renamed ArrayInterpolator to MultiValueInterpolator (and enhanced behavior to handle Vectors as well as Arrays).
      - Created new AnimateTransform3D subclass of AnimateTransform (to hold 3D-specific properties/defaults), and moved Move3D, Rotate3D, Scale3D to subclass from this new class.
      QE Notes: Change to default value of applyLocalProjection (matches former default on 3D effects, but not default on AnimateTransform).
      Doc Notes: None
      Bugs: None
      Reviewer: Hans
      Tests: checkintests, effects cyclone from QE
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/Animate.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimateTransform.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/Move3D.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/Rotate3D.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/Scale3D.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/animation/Animation.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/animation/MotionPath.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/animation/SimpleMotionPath.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/AnimateInstance .as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/AnimateTransfor mInstance.as
          flex/sdk/trunk/frameworks/spark-manifest.xml
      Added Paths:
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimateTransform3D.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/interpolation/MultiValueInterp olator.as
      Removed Paths:
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/interpolation/ArrayInterpolato r.as
