0 Replies Latest reply on Jun 22, 2009 1:38 PM by Paul Reilly
    [svn:fx-trunk] 8060: * Fixed global SWC cache issue with frameworks projects and fcsh issue
    Paul Reilly Level 1
      Revision: 8060
      Author:   preilly@adobe.com
      Date:     2009-06-22 13:38:01 -0700 (Mon, 22 Jun 2009)
      Log Message:
      • Fixed global SWC cache issue with frameworks projects and fcsh issue
        with compiling too many files.
      tests Passed: checkintests
      Needs QA: YES
      Needs DOC: NO
      Bug fixes: SDK-21824, SDK-21870
      API Change: NO
      Reviewer: Pete F.
      Code-level description of changes:
        CompilerAPI.java
          Modified validateCompilationUnits() to use the qName instead of
          the dependentName.
        io/InMemoryFile.java
          Modified equals() and hashCode() to use the lastModified and
          bytes.length in addition to the name, so that defaults.css files
          from different SWC's don't overlap in Set's and Map's.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-21824
          http://bugs.adobe.com/jira/browse/SDK-21870
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/io/InMemoryFile.java
