1 Reply Latest reply: Jun 22, 2009 4:00 PM by nope0000 RSS
    define DataMergePreference arrangeby and recordsperpage
    nope0000 Community Member
      I try to merge data from a csv file in InDesign CS3 with vbscript. the first script below works fine, but how can i arrange multiple records by columns or rows per page? Setting DataMergePreference.ArrangeBy and DataMergePreference.RecordsPerPage just won't work.
      merging with ID default settings (one record per page) works fine with this code:
      set arg = WScript.Arguments
      idYes = 2036691744
      idNo = 1852776480
      idNeverInteract = 1699640946
      idInteractWithAll = 1699311169
      idColumnsFirst = 1684882278
      idMultipleRecord = 1684884850
      Set myInDesignApplication = CreateObject("InDesign.Application.CS3")
      Set myDocument = myInDesignApplication.Open(arg(0),True)
      Set myDataProperties = myDocument.DataMergeProperties
      myInDesignApplication.scriptPreferences.userInteractionLevel = idNeverInteract
      myDataProperties.SelectDataSource(arg(1))
      myDataProperties.MergeRecords()
      myDocument.Close idNo
      myInDesignApplication.findTextPreferences.findWhat = "\r\n"               rem works in cs3
      myInDesignApplication.changeTextPreferences.changeTo = "^p"          rem works in cs3
      myInDesignApplication.ActiveDocument.changeText                           rem works in cs3
      myInDesignApplication.ActiveDocument.Close idYes, arg(2)
      If myInDesignApplication.Documents.Count < 1 Then
      myInDesignApplication.Quit
      Else
      myInDesignApplication.scriptPreferences.userInteractionLevel = idInteractWithAll
      End If
      merging multiple records by coumn with something like the following doesn't work:
      idYes = 2036691744
      idNo = 1852776480
      myDataProperties.RecordsPerPage = idMultipleRecord
      myDataProperties.ArrangeBy = idColumnsFirst
      Else
      End If
      I tried everything to set RecordsPerPage and ArrangeBy, nothing worked:
      myInDesignApplication.RecordsPerPage = idMultipleRecord
      myInDesignApplication.ArrangeBy = idColumnsFirst
      nor
      myDocument.DataMergePreference.RecordsPerPage
      myDocument.DataMergePreference.ArrangeBy
      myDocument.DataMerge.DataMergePreference.RecordsPerPage
      myDocument.DataMerge.DataMergePreference.ArrangeBy
      myDocument.DataMerge.DataMergePreferences.RecordsPerPage
      myDocument.DataMerge.DataMergePreferences.ArrangeBy
      followed by = idMultipleRecord/idColumnsFirst or (idMultipleRecord/idColumnsFirst).
      What am i doing wrong?
      Would be great if anyone can tell me how to use Indesign Library's "idXXXXX" the right way (without defining variables like i did)
      Never had problems like this when coding in c, c++ or c#...
        • 1. Re: define DataMergePreference arrangeby and recordsperpage
          To merge multiple records per page arranged by collumn in VBScript do something like
          Set myDocument = myInDesignApplication.Open(c:\not_dev_null\document.indd,True)
          myDataProperties.SelectDataSource(c:\not_dev_null\data.csv)
          myDataProperties.DatamergePreferences.RecordsPerPage = idMultipleRecord
          myDataProperties.DatamergePreferences.ArrangeBy = idColumnsFirst
          DatamergePreferences is Member of InDesign.DataMerge, that is Interface to Property like i.e. InDesign.Document.DatamergeProperties.
