4 Replies Latest reply on Jan 9, 2018 9:23 PM by Rick Gerard
    Can After Effects co work with Excel?
    swt__100
      it's sound crazy.but yes that's what i want.
      i work for TV station ,major in graphic DEPT
      i am incharge of subtitle daily update.
      every day i got a excle file from pre-broadcasting DEPT ,then i copy and paste the wording from excle to aftereffect's different layers then add fade in\fade out effect and render then.
      actually, it's not a hi-tech,but workload is huge!
      i have to copy paste 200+ every day, freak out...
      is it possible that AE can import wording automatic paste them into the layer?
      thanks for reading my crazy thought...
      lol
      Message was edited by: Andrew Yoole - Corrected title spelling for clarity
        • 1. Re: Can After Effect co work with Excle
          Adolfo Rozenfeld Adobe Employee
          swt:
          Here is a script by Dan Ebberts in his web site that will take each line in a text document a turn it into an After Effects text layer.
          So, if you to save your Excel documents as text, it should help-
          • 2. Re: Can After Effects co work with Excel?
            In addition to the simple text from file script pointed out, you may also wish to look into things like the ones below:
            Create Lower Thirds from Text
            Create Markers from Text
            They may not contain the perfect solution you seek, but the code could be modified to suit your needs. there's a couple of more scripts out there with similar functionalities, most of which can be found on or via AEnhancers.
            Mylenium
            • 3. Re: Can After Effects co work with Excel?
              Pat Mck
              It would also be handy to import such things as transformation and key frame data from an Excel spreadsheet, which can be an easier method of importing and changing to repeated items.
              • 4. Re: Can After Effects co work with Excel?
                There are several scripts available that can create lower thirds from CSV and other data files. If you have the same transformations applied to each layer you can create animation presets that do the animation automatically with one click. I have about 200 that are based on the layer in and out points so all I have to do in create the text layers and then select them and apply the animation preset I choose. If you wanted to get fancy you could write your own custom script that created the text layers, applied an animation and trimmed the layers to length to make a complete lower 1/3 or other typical news graphics completely automatically. It would take a bit of study or experiment with some of the scripts available for purchase.
