0 Replies Latest reply on Jun 23, 2009 1:44 AM by neil wilkes
    "Edit Menu in Photoshop" not working?
    neil wilkes Adobe Community Professional & MVP
      If you have installed a new version of Photoshop, you may find that the command to "Edit Menu in Photoshop" no longer works.
      The fix for this is simple. Just re-associate the .PSD extension with the new version of Photoshop.
      You can do this in a couple of ways (all versions of Windows).
      1 - Find a folder with a .PSD file in it.
      Right-click the file, and choose the "Open With" dialogue.
      Select the new installation of PhotoShop, and make sure that the check-box for "Always use this programme" is ticked.
      Click on Open, and from now on all PSD files should be associated with the new installation. Some systems might require a restart to lock the association in.
      2 - Go to Start/Settings/Control Panel/Folder Options.
      Click on the tab marked "File Types".
      Scroll down to the PSD type, and set the "open" command to the new installation of Photoshop.
      That will do it.
