5 Replies Latest reply on Jun 25, 2009 3:38 AM by IrishAIRMax
    Digital Signature?
    IrishAIRMax Level 1
      Hi Everyone,
      I'm a student and for my MSc project I have choosen to create a AIR app.
      But how do I test my air app without purchasing a Digital Signature as I cannot afford that?
      Thanks in advance,
      IrishAIRMax
        • 1. Re: Digital Signature?
          Michael Borbor Level 4
          You don't need a digital certificate, your test user will get a warning that
          your app can't be verified but they would be able to install your app, and
          run it without any issues.
          • 2. Re: Digital Signature?
            IrishAIRMax Level 1
            Thanks for getting back to me Michael,
            I can't seem to make a .air file without signature. The only option Flash Builder is giving me is to create .air with digital signature or .airi without signature.
            Even when I try to run the application, it does not appear on screen and if I click on the button a second time, it tells me that the app is already running and must be shut down first. But it did not appear on my screen? Or in my processes?
            I tried to create a digital signature myself via
            http://help.adobe.com/en_US/AIR/1.5/devappshtml/WS5b3ccc516d4fbf351e63e3d118666ade46-7f74. html
            and
            adt -certificate -cn name [-ou org_unit][-o org_name][-c country] key_type pfx_file password
            but I am using Vista and this looks like linux command line to me?
            Any help would be really appreciated!
            Thanks so much!
            IrishAIRMax
            • 3. Re: Digital Signature?
              Joe ... Ward Level 4
              I haven't used Vista, but surely there is a way to get to a command prompt.
              Also, Flex Builder 3 had a way to create your own signature file. Did they remove that from Flash Builder?
              • 4. Re: Digital Signature?
                tzeng Adobe Employee
                You should be able to use Flash Builder to create a self signed certificate.
                If you use adt to generate the certificte, you need to install Java first. Then launch command-prompt by clicking the start button, then type
                cmd <Enter>
                Then you can generate the cert using adt.
                • 5. Re: Digital Signature?
                  IrishAIRMax Level 1
                  Thank you all for your help.
                  yes i tried the command given above in the command promt but I think it is a Linux/Apple command and not a windows command, that is where the problem lay there.
                  To give a concreate answer for anyone who looks at this post and has the same problem, yes within Flash Builder, you can create a self-signed signature. This is done by the "create..." button beside the "browse" button in the digtial signature section the UI box.
                  I got confused by the "create..." button cause I thought it was to create a digital signature through one of the companies that offer the service, my bad, in reflection, once I had done it, this was a pretty stupid quesion although, there is a big difference between Digital Signature and Self Signed Signature, should Adobe of put a third radion button in? There was plenty of space in the UI box for it?
                  Thank you all for your help again, much appreciated
                  IrishAIRMax
