1 Reply Latest reply on Jun 23, 2009 7:09 AM by Jim_Babbage
    Wrapping text around a circle problems
      I must be doing this wrong, as my test looks jagged and does not really follow my circe auto-shape that accurately. I'm slecting both the text and the auto-shape and then going to Text> Attach to Path.
      I'm creating a logo (attached), and I have two auto-shapes, one main one which has all of the icons inside, and that circle is sitting on top of another one that is 30px wider/taller in diameter. The gutter that this generates is where I'd like to put my circular text. I apologize, becuase I'm sure this has been answered beore, I just couldn't track down the thread.
        • 1. Re: Wrapping text around a circle problems
          Jim_Babbage Level 4
          Well unless you mean the icons, I don't see any text.
          By default, text wraps around the outside of a circle, so what need is
          a circle that is the same size or just slightly larger than your inner
          circle. Text should wrap around that.
          There are several text settings which can change this however:
          in the Property Inspector , check your text alignment and the Offset.
          In The Text menu, try out the different orientations/directions.
          Note also that the circle vector (It's not an auto shape, just a
          regular vector shape) has a "starting node". The control handle on the
          left side is where the path "begins" for lack of a better term, and
          text will start from that point and move to the right, unless changes
          are made in the PI or the Text menu.
          Jim Babbage
