0 Replies Latest reply on Jun 23, 2009 7:30 AM by Darrell Loverin
    [svn:fx-trunk] 8087: Second half of fix for SDK-21711
    Darrell Loverin Level 4
      Revision: 8087
      Author:   dloverin@adobe.com
      Date:     2009-06-23 07:29:50 -0700 (Tue, 23 Jun 2009)
      Log Message:
      Modified SwcDependencyUtil to be more aggressive at removing dependencies when ?\226?\128?\156minimizeDependencySet?\226?\128?\157 is true. When ?\226?\128?\156minimizeDependencySet?\226?\128?\157 is true the code applies rules to find the ?\226?\128?\156original?\226?\128?\157 source swc for a script when a script is found in more than one swc. The rules are described in the getOriginalSwc() method.
      Modified SwcDependencies to turn on ?\226?\128?\156minimizeDependencySet?\226?\128?\157 by default.
      QE Notes: swcDepends has "minimizeDependencySet" set to true by default.
      Doc Notes: none.
      Bugs: SDK-21711
      Reviewer: Pete
      tests: checkintests
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-21711
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/SwcDependencyUtil.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/SwcDependencies.java
