0 Replies Latest reply: Jun 23, 2009 9:14 AM by pmd12345 RSS
    [svn:fx-trunk] 8095: Ongoing refactoring and simplification of the Asc parser
    pmd12345 Community Member
      Revision: 8095
      Author:   peted@adobe.com
      Date:     2009-06-23 09:14:26 -0700 (Tue, 23 Jun 2009)
      Log Message:
      Fixed a regression related to xml,regex,divide ambiguities (that I created).
      Several asc tests updated for slight change in error message behavior.
      QE: Gaurav to add new mx tests
      Doc: No
      Checkintests: Pass
      Reviewer: Gaurav
      Bugs:
      ASC-3759
      Ticket Links:
          http://bugs.adobe.com/jira/browse/ASC-3759
      Modified Paths:
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/Parser.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/Scanner.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/Context.java
          flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/Function/PrivStatStatNameErr.err
          flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/Function/PubStatStatNameErr.err
          flex/sdk/trunk/modules/asc/test/compiler/as3/Directives/Attributes/ClassAttrErr4.err
          flex/sdk/trunk/modules/asc/test/compiler/as3/Directives/Attributes/IfAttrErr4.err
          flex/sdk/trunk/modules/asc/test/compiler/as3/Directives/Attributes/VarAttrErr12.err
          flex/sdk/trunk/modules/asc/test/compiler/as3/Directives/Attributes/VarAttrErr13.err
          flex/sdk/trunk/modules/asc/test/compiler/as3/Directives/Attributes/VarAttrErr17.err
          flex/sdk/trunk/modules/asc/test/compiler/as3/Directives/Attributes/VarAttrErr21.err
          flex/sdk/trunk/modules/asc/test/compiler/as3/Directives/Attributes/VarAttrErr22.err
          flex/sdk/trunk/modules/asc/test/compiler/as3/Directives/Attributes/VarAttrErr26.err
          flex/sdk/trunk/modules/asc/test/compiler/as3/Directives/Attributes/VarAttrErr30.err
          flex/sdk/trunk/modules/asc/test/compiler/as3/Directives/Attributes/VarAttrErr4.err
          flex/sdk/trunk/modules/asc/test/compiler/as3/Directives/Attributes/VarAttrErr8.err
          flex/sdk/trunk/modules/asc/test/compiler/e4x/TypeConversion/toXMLStringErr.err
          flex/sdk/trunk/modules/asc/test/compiler/ecma3/e7_3_13_Err.err
          flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b115412.err
