1. Re: Converting Word 2003 doc to Adobe pdf loses some text
MichaelKazlow Jun 23, 2009 7:00 PM (in response to GalfromKalamazoo)What method of creating pdf files are you using? Do you have the Adobe PDF printer instance set as the default system printer?
2. Re: Converting Word 2003 doc to Adobe pdf loses some text
GalfromKalamazoo Jun 24, 2009 5:47 AM (in response to MichaelKazlow) -
3. Re: Converting Word 2003 doc to Adobe pdf loses some text
Bill@VT Jun 24, 2009 7:21 AM (in response to GalfromKalamazoo)It appears that you printed to the Adobe PDF printer from WORD.
You might find the problem resolved if you updated from AA9.0.0, though you may have and that is just the Distiller version. The early versions typically have problems. If you update, be sure to install the updates in order and do not try to skip over updates unless an update specifically says cummulative.
Apparently the two processes you use are different (as asked by the other post) and that is likely the issue. However, the one with the missing lines has all fonts embedded. The other one does not, and also uses additional fonts. It appears that one process may be using PDF Maker, though normally that would be indicated in the metadata and is not indicated as such. So, giving us more information about the process that you selected for creating the PDF in both cases may give us the info we need to help.
4. Re: Converting Word 2003 doc to Adobe pdf loses some text
GalfromKalamazoo Jun 24, 2009 7:27 AM (in response to Bill@VT)
