1 Reply Latest reply on Jun 23, 2009 5:26 PM by EMelville
    I Setup RemoteObject Ok! But not the effect i'm looking for?
    EMelville Level 1
      So my goal is to simply make the txtID box below disappear... that's right!.... on everyone's screen. (Code is in bold)
      Can you tell me what i'm missing? The Code works ok below, just when I initiate the  writefn(); command, the textbox "txtID" only disappears on my screen, no one elses. I've got to be close...
      Take a look:
      <mx:Script>
                 <![CDATA[
                      //variables
                      public static var nc:NetConnection;
                      public static var module_so:SharedObject;
                      //init function on creationComplete
                      public function init():void
                            nc = new NetConnection();
                            nc.connect("rtmp://media.thealphacompany.net/ambientdemo");
                            nc.addEventListener(NetStatusEvent.NET_STATUS, netStatusHandler);
                      //netStatusHandler function
                     public function netStatusHandler(e:NetStatusEvent):void
                                     switch (e.info.code)
                                      case "NetConnection.Connect.Success":
                                          my_connection_label.text="CONNECTED";
                                          initRSO();
                                              break;
                                      case "NetStream.Play.StreamNotFound":
                                            my_connection_label.text="DISCONNECTED";
                                              break;
                           trace( "netStatusHandler : " + e.info.code );
                      //init remote shared object
                   public function initRSO():void
                        module_so = SharedObject.getRemote("module", nc.uri, true);
                        module_so.addEventListener(SyncEvent.SYNC,rsoHandler);
                        module_so.connect(nc);
                   //remote shared object handler
                   private function rsoHandler(e:Object):void
                        trace("SyncEvent.SYNC");
                      //write-set remote shared object when writeSO button is released
                   public function writefn():void
                             module_so.setProperty("PollQ",txtID.visible=false);
                   //read remote shared object when readSO button is released
                   public function readfn():void
                             my_rso_label.text=module_so.data.PollQ;
           </mx:Script>
           <mx:Label x="423" y="144" text="Label" id="my_connection_label"/>
           <mx:Button x="423" y="170" label="writeSO" id="writeSO" click="writefn();"/>
           <mx:Button x="502" y="170" label="readSO" id="readSO" click="readfn();"/>
           <mx:Label x="423" y="198" text="Label" id="my_rso_label"/>
           <mx:TextInput x="94" y="248" id="txtID"/>
        • 1. Re: I Setup RemoteObject Ok! But not the effect i'm looking for?
          EMelville Level 1
          I've updated these two values:
                                 module_so.setProperty("PollQ",false);
                                 if (module_so.data.PollQ == false){
                                 txtID.visible = false;
          However, still trying to have it remove that txt box automatically for all users
