0 Replies Latest reply on Jun 23, 2009 4:08 PM by Chet Haase
    [svn:fx-trunk] 8131: Fix for 2 gumbo_priority bugs.
    Chet Haase
      Revision: 8131
      Author:   chaase@adobe.com
      Date:     2009-06-23 16:08:25 -0700 (Tue, 23 Jun 2009)
      Log Message:
      Fix for 2 gumbo_priority bugs. One was a miscalculation of a Parallel effect's duration when it had zero-duration child effects, causing a problem when seeking into that parallel effect. The other was a fix to the easing model for transform effects. Now a transform effect will handle easing through its internal keyframes, preserving the behavior specified by the caller (or by the default easing behavior).
      QE Notes: None. Behavior for AnimateTransform should be as before, although the way easing is applied to the subclasses has changed (and is now correct)
      Doc Notes: None
      Bugs: sdk-21477, sdk-21422
      Reviewer: Jason
      Tests: checkintests, Mustella spark/effects
      Ticket Links:
          http://bugs.adobe.com/jira/browse/sdk-21477
          http://bugs.adobe.com/jira/browse/sdk-21422
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/ParallelInstanc e.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/AnimateTransform.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Move.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Move3D.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Rotate.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Rotate3D.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Scale.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Scale3D.as
