0 Replies Latest reply on Jun 24, 2009 7:03 AM by Paul Reilly
    [svn:fx-trunk] 8165: * Customer patch for compiler extension support.
    Paul Reilly Level 1
      Revision: 8165
      Author:   preilly@adobe.com
      Date:     2009-06-24 07:02:59 -0700 (Wed, 24 Jun 2009)
      Log Message:
      • Customer patch for compiler extension support.
      tests Passed: checkintests, junit
      Needs QA: YES, there are some customer unit tests that need to be
                integrated into our automated builds.
      Needs DOC: YES
      Bug fixes: SDK-18718
      API Change: Yes, adds new API for compiler extensions
      Reviewer: Me
      Cycloner: Gaurav
      Code-level description of changes:
        tools/oem/Application.java
        tools/oem/Library.java
          Added runExtensions() and modified build() to call it.
        tools/oem/Configuration.java
          Added setExtensionLibraries() and addExtensionLibraries().
        tools/oem/internal/ConfigurationConstants.java
          Added COMPILER_EXTENSIONS constant.
        tools/oem/internal/OEMConfiguration.java
          Changed args, defaults, more, linker_args, and linker_more from a
          TreeMapAdapter to a Map<String, Object>.
          Removed TreeMapAdapter inner class.
          Added getExtensions(), setExtensionLibraries(), clone().
        tools/Compc.java
          Refactored compc(String[] args) by moving the bulk of the logic
          into compc(ConfigurationBuffer cfgbuf, CompcConfiguration
          configuration).
        tools/PreLink.java
          Modified run() to call run() on each extension.
        tools/flexbuilder/BuilderConfiguration.java
          Added addExtensionLibraries() and setExtensionLibraries().
        tools/CompcConfiguration.java
          Added setIncludeSources().
        tools/Mxmlc.java
          Modified mxmlc() to call run() on each extension.
        compiler/CompilerAPI.java
          Modified compile() to call run() on each extension.
        compiler/common/CompilerConfiguration.java
          Added extensionsConfig and getter.
        compiler/common/Configuration.java
          Added clone().
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-18718
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/CompilerConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/Configuration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/CompcConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/PreLink.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/flexbuilder/BuilderConfiguration.jav a
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Application.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Configuration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/ConfigurationConstants. java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/OEMConfiguration.java
      Added Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/ExtensionManager.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/ExtensionsConfiguratio n.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/IApplicationExtension. java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/ICompcExtension.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/IConfigurableExtension .java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/IExtension.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/ILibraryExtension.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/IMxmlcExtension.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/IPreCompileExtension.j ava
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/IPreLinkExtension.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/util/
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/util/ListMap.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/extensions_en.properties
