3 Replies Latest reply on Oct 26, 2009 3:58 PM by sluggothecat
    Error
    evilon
      I am getting the error below on the output tab of Flash. I can click on the timeline tab but it will not let me do anything on the timeline it goes back to the output tab and shows more errors.
      This is error upon opening flash:
      Plugin tool script error in method initIK
      Plugin tool script error in method ik_setAutoTransformPoint
      Once I open a new document I get all of this:
      Plugin tool script error in method ik_activateTreesFromSelection
      Plugin tool script error in method ik_redraw
      Plugin tool script error in method ik_isIKContainer
      Plugin tool script error in method ik_hitElementOfActiveTree
      Plugin tool script error in method ik_hitTestBone
      Got any ideas?
        • 1. Re: Error
          jendehaan Level 4
          Do you have any extensions installed? If you do, try temporarily uninstalling extensions from Extension manager and see if that gets rid of the error.
          If that doesn't work, I would try removing your user configuration folder and restarting flash.
          • 2. Re: Error
            sluggothecat
            Actually, the problem is in the DLL files located in the Common/Configuration/External Libraries folder. It turns out that if you install Flash and these files have the Archive bit turned off, your program refuses to load the DLL files. We have confirmed this by watching the DLLs being loaded.
            All you have to do is open this folder (/Program Files/Adobe/Adobe Flash CS 4/Common/Configuration/External Libraries) in a command prompt and type:
            ATTRIB +A *.*
            For some reason, the software developers are watching for the Attribute flag on these files and refusing to load them if this is not set. Bad programming....
            • 3. Re: Error
              sluggothecat Level 1
              ATTRIB +A *.*
